cencerrita's avatar
cencerrita
Explorer II
Jul 11, 2017
E450 superduty front window curtain size
Hi, our RV is in storage a long way from us and when we next collect it we are going to move the storage out West. At present we get free mains power plug in for our battery maintainer, but when we move we will need to fit a front window solar trickle charger. We want to make and fit new inner curtains tight against the front and 2 side door windows to stop the heat, allowing the solar unit to be between the window and curtain.
Please would someone be kind enough to measure their E450 superduty window sizes width and full depth tight against the bottom of the window as we want to protect the dash from the sun. (Tried looking at the external thermal curtains for sale but none have the actual measurements)
Greatly appreciated,thanks
  • I would think that most any Ford dealer or RV dealer near you would have an Econoline or two that you could measure, have you thought about that?
  • We use a truck size sun screen from one of the auto stores. Covers the front and is reflective to keep sun out and some heat. For the side windows I used another and cut it in half and then folded as needed. I did add some suction cups to keep all tight to window but they eventually dry out. For the front I just put the visors down, sides just cut a little bigger and push into window channels.
    Make akk for less than $10 and are less hassle than curtains.
