theoldwizard1 wrote:
Desert Captain wrote:
Nice to see that the myth of using higher octane to solve mechanical problems is still alive. :S
30+ years of automotive engineering disagrees with you.
I qualified my response by saying "ping" from pre-ignition can be cured by higher octane. Why the pre-ignition is occurring is hard to diagnose, but likely it is from carbon build up inside the combustion chamber.
Higher octane fuel will not ignite until a higher in cylinder temperature is reached, such as an actual spark event nor just a "hot spot".
In my case, anecdotal evidence proves I am correct.
Nice job cherry picking my quote. "Ping" in a V-10, if in fact that is the problem, is not caused by running 87 octane gas. The V-10 was designed and engineered to run perfectly on 87 and running 93 is merely a waste of money misdirected at a problem that has not been addressed. The source of the problem needs to be identified and dealt with and buying 93 octane gas is at best a band aid solution. Like I said, Google it.
I did and here is an interesting article by a Ford engineer on the real impact of using the wrong octane:
http://oppositelock.kinja.com/the-real-impact-of-using-wrong-fuel-octane-1785829176
As always... Opinions and YMMV.
:C
