JACKLEEExplorerJun 17, 2013Electric fuel pump on 1990 pacearrow 460 v-8My electric fuel pump will not pump with key in on position. It will pump when I crank the engine only. Is there a relay and where is it or could it be the Ignition switch on column? This is on a...Show More
whem2fishExplorerJun 17, 2013my p-32 is the same the fuel puml is tied into the oil pressure switch so no oil pressure no fuel pump
Related ContentElectricElectrical assistanceElectrical outlet issuesSurge or electric brakeshelp with outlets not working in 2019 pacearrow 36u
