MrWizard wrote:
It's nice that it works
Nobody is saying it doesn't work
Only that you are confused on how it works
It's called a 'pump' because it moves heat from the outside air to the inside
It does Not extract heat from air inside to move it inside
You have a hose to the outside and that is where the heat comes from the 'outside' air
Think the Moderator is CORRECT.
It's called a 'pump' because it moves heat from the outside air to the inside.
This is the Science of the Heat Pump ....BUT....if the outside air is "Leaking into the Inside air" ...............then just maybe, you could be partially correct?
But sure seems as if it just may be Magic, as it goes against the Science of a Heat Pump.
But ........................(long pause) ......if you are happy with the way it works for you fine, not worth getting all excited about ..............(another long pause)........
So as my Granddaughter would say "Just Calm Down" Guy's
Sometimes we DO NOT KNOW ALL THE FACT's........Could it be that it is expelling/Pumping out the Cold Air?
JMHO,
