chrisandoctavia's avatar
Mar 05, 2016
Electric Tank Blankets
I've previously asked a question about "Winterizing" an RV - and have recently received emails from Camping World advertising electric water tank blankets
http://www.campingworld.com/shopping/item/tank-blanket-40-gallon-ac/71649
Does anyone have experience of fitting these?
How many do you need?
Clearly you would need one for your potable fresh water tank - but do you also need them for either black or grey waste tanks?
If you use them do you power them from the RV's internal A/C - or plug them into a spare A/C socket in your shoreside power pedestal?
Chris
  • Tank blankets are not a substitute for winterizing if you're in a cold climate and not usig the RV. Tank blankets will keep tank contents from freezing but do nothing for all the water lines and drain outlets.
  • If the tank area is not heated and enclosed you need heaters for all tanks as well as for the valves and elbows.
    Some of them are dual voltage--12 volt while traveling and 120 volt at a campground.
    I would make mine a flexible install as there is not always an extra outlet on the pedestal.
