kohlerguy's avatar
kohlerguy
Electrical outlet head scratcher
I have a 05 Newmar DutchStar. I'm having trouble with 2 outlets. All other outlets work fine. These two outlets only have about 100v to each one. All others have about 118-121v. The 2 problem outlets work good as long as you don't put a heater, fan, vacuum cleaner on it. When that happens it knocks out the inverter. A quick reset and all is well again.
House batteries are both showing 13.6 volts.
Anyone have an idea what to check next. I'm assumming the inverter is good as all the other outlets will work even under load.
Any ideas?
  • Pull them out and check the voltage at the wires. Probably burned contacts in the receptacles.
