darsben
Jun 11, 2014Explorer II
Another possible cause could be corrosion inside the Aux switch under the hood. I had a similar problem with my switch. Took it off (disconnect power first) and removed the screws holding the top and bottom of switch together. Clean the big washer that is in there and the two brass contacts. this may cure the problem
38,707 PostsLatest Activity: Feb 22, 2025
