Vintmxman's avatar
Vintmxman
Electrical problem
Been having an ongoing problem I can't seem to fix. My 2006 four winds winds 5000 keep blowing the house solenoid. It will work for a day or two as it should an then it's blown. Appears to be getting very hot. I have replaced the complete charging unit , batteries, cables , disconnect switch etc but still keeps happening. Not sure what to replace or check next. This has been a royal pain...Really has been ruining out summer camping trips. Having no house lights after less than a day is a royal bummer.....anyone has any ideas or thoughts on what could be happening ? Or maybe an alternate method to control power without the solenoid ?
  • tenbear wrote:
    By "house solenoid" do you mean the one that connects the chassis battery to the house battery when the ignition is on?
    I replaced mine years ago and it has been fine since. The original was installed upside down. I don't know if this contributed to the failure but I installed the new one right side up.
    Dusty R may have the right idea.
    No, the house battery to the house electrical panel that lives under the bed...
  • Dusty R wrote:
    Sounds like the original solenoid died and you replaced it with one that was not a continuous duty.
    I replaced it with the same exact one that was in the coach as original equipment...
  • ronfisherman wrote:
    Have you checked for a bad ground to the solenoid?
    No. I don't know how too...but am a quick study if instructed well...
  • By "house solenoid" do you mean the one that connects the chassis battery to the house battery when the ignition is on?
  • Sounds like the original solenoid died and you replaced it with one that was not a continuous duty.
