BlendedRVFam's avatar
BlendedRVFam
Electronic Driving Systems
Hi! We're looking to buy a Class A to full-time with our 4 kids. I'm having trouble locating this info and wondered if you knowledgeable folks could help. What years were the electronic Driving Systems put in motorhomes? Specifically, Tiffin, Monaco, Winnebago, Newman. I'm basically wondering how old of a home we could buy that still has the systems we'd like- stability, braking, traction, adaptive cruise control, etc. I realize these can be added after-market but I'd prefer to not go that route. Thanks so much!
  • Executive wrote:
    In the Monaco line, only the luxury coaches were built on a steel frame. All the others are aluminum. Only if you're concerned about rolling your coach over from time to time. Rarely do you find coaches rolling over although it does occur...Dennis
    Sorry Dennis , I think you meant to say the metal cage ( frame )
    the house / body is built around is aluminum on some models .
    Monaco started using aluminum frames for the body in 03 AFAIK
    The actual chassis / frame is steel on all of them .
    Ray
  • In the Monaco line, only the luxury coaches were built on a steel frame. All the others are aluminum. Only if you're concerned about rolling your coach over from time to time. Rarely do you find coaches rolling over although it does occur...Dennis
  • The more complex the system the greater the likelihood of failure. I would stay away from such items.
  • IMO... The ultimate roll over protection (not prevention)
    Is a Bluebird wander lodge
  • BlendedRVFam wrote:
    Maybe, but I figure layouts can be modified, electronics cannot as easily. So stability control, rollover prevention, things like that are typically only found on the higher end brands?
    Only Prevost and Newell for the stability control and rollover prevention build in. Could be wrong and left out a some.
  • Maybe, but I figure layouts can be modified, electronics cannot as easily. So stability control, rollover prevention, things like that are typically only found on the higher end brands?
  • Maintenance records and condition as determined by a house and chassis inspection by a pro is far more important when considering an older A IMO.
  • Not sure what electronic driving systems mean to you. Power steering, automatic trannys, cameras etc are common for at least 20 years. Adaptive cruise control (depending upon what you mean by that) is not as common except perhaps higher end models.
    I'm wondering if you're focused on the wrong items considering you'll have 6 people living in a very small area? Maybe you could find a MH with bunk beds. ie Living space might be more important than driving considerations.
