gatorcq
Jul 29, 2013Explorer
Ours is hinged at the top. Only 1 handle on the right side. Pull down, bottom latch slides. Push open, if it has not been used or tried, then it is possible the old lube will make it stick. Push on the bottom. When closing let is slam down, away from the window about 10 inches. DOES NOT LEAK AFTER USE.
38,783 PostsLatest Activity: Sep 22, 2026
