John_Wayne
Jul 29, 2013Explorer II
Some will open part way enough to put 303 on the rubber seal so it doesn't stick closed, BUT if opened to far the whole window will fall off the MH. National has some that work this way and Winnabago is that way also. Some have a string or rope that you pull this type will release the glass which will fall out.
If you can't see a hinge at the top don't press your luck open it enough to lube the rubber seal and that's all.
38,783 PostsLatest Activity: Sep 22, 2026
