klutchdust
Jan 28, 2016Explorer II
Engine battery and house battery questions.
My coach sat for about 8 weeks. Went to move it and the engine battery was dead, drained, kaput. House batteries were fine, they were replaced recently with new
deep cells. Anyway I used the bypass/boost switch to start the engine. There is a switch where you can designate the radio to run off of the house or engine. Should
that switch be in either direction for a benefit or is it just to run the radio without having to turn the ignition on.The house batteries charge off the generator or
engine but the engine battery just charges off the engine correct? I am charging engine battery now and will do a test to see if it has a dead or weak cells tomorrow.
I did not have the coach on ground power while it sat, it's in my backyard and periodically I was going in and pushing the indicator switch to see how the house
batteries were. Thanks....
