Davion206's avatar
Davion206
Engine battery
What would drain the engine battery on our 2017 class c? Went to unlock the doors on our class c mh with the remote and zilch....tried the auto door locks from inside and zilch....put the charger on the engine battery and started the engine to let it run. It has been stationary for a few months now.
  • With all the engine computers with memory the battery will go down in a few days. Twenty plus years ago the batteries would hold for several weeks.
    Dusty
  • Radio, OBD/PCM, most likely culprits.
    Courtesy lamp under hood with faulty mercury switch, if there is one there, or else where.
    Apparently some power electric steps can draw current from the chassis/engine battery.
    Door not closed dome light?
    Lots of things can do it over a few months.
  • Just a guess, the radios memory draws about 50mA and over a few months will deplete the charge on the radio. I added a switch to allow me to turn off the memory when I think I may not be using the M/H for more than 30 days.
