- gsf35099ExplorerBefore you order a new handle, take it off and see if it is a easy bulb replacement or the LED resistor style. Mine was the LED, resistor style. Radio shack carries the LED's & resistors and you can even get a little larger set to have more light. I used one size up on the led & a 450 ohm resistor. The cone around the led will need to be drilled out a little for the new led to fit, but it will glow like crazy. I used the blue and we love it. :B
Really cheap fix just takes a little patience with the solder gun. - retiredhfdExplorerMine went out also and the other responses are correct. I replaced my light bulb with a similar type led bulb I found at West Marine. It worked ok but not quite as bright as the original light. I finally ordered the whole new handle from Fleetwood. Good luck.
- Big_KatunaExplorer IIFleetwood owner here. Yes, you can take the handle off and replace the LED. You will need your FIN if you get it from Fleetwood. I called and ordered on. If you are keeping your RV, you might want to order a complete new handle. Mine has crazed and the chrome rusty and looks like heck. I think the LED was $20 with shipping.
- TZScalesExplorerFleetwood Couple,
Welcome to the Forum. It is my presumption that there are screws at the top and bottom that secure the lighted handle. Try removing these to determine if you can access the bulb(s). You can also contact Fleetwood and provide your coach number. I am sure there is someone who can get you started.
Best of luck. Post back your findings. Thanks.
38,748 PostsLatest Activity: Aug 03, 2025
