cpd520's avatar
cpd520
Entry door latch replacement
I received the replacement parts for a broken entry latch on my 2004 Itasca Suncruiser.
The handle portion came out easily. I can not figure out how to remove the latch portion which is inside the door. Hope I don't have to take the door apart.
Anyone done this repair and want to help a brother out??
  • Just FYI. The part (single rotor latch) will not wiggle out. According to Winnebago, I will have to remove the door edge trim.
    Thanks all for the input.
  • Jiggle it, work from the side toward the center of the door. If all the screws are out, it will come out.
  • Argosy24 wrote:
    Does it unscrew from the edge of the door?
    It does have 3 screws through the edge of the door into the latch assembly. I removed the screws and still can't get the assembly out. It seems to be in a channel that is keeping it from coming out.
