- bkd148ExplorerThank you for the replies. Marty
- Tom_M1ExplorerIf covering the base with Dicor forget those mounting bases and just use an adhesive such as Dicor. If exposed to sunlight, those mounting bases will self destruct in a couple of years and the adhesive tape used dries up.
- 3oaksExplorer
Teacher's Pet wrote:
Now that's the way I would go. Easier to remove, should the cable ever need replacing or rerouting.
I used wire ties and self adhesive mounting bases to position the cable where I wanted it to run on the roof then covered the mounts with attached cable with DiCor lap sealant. So far the installation has lasted 9 years without any problems. - Teacher_s_PetExplorerI used wire ties and self adhesive mounting bases to position the cable where I wanted it to run on the roof then covered the mounts with attached cable with DiCor lap sealant. So far the installation has lasted 9 years without any problems.
- CrabbypattyExplorerWorks great. I used it for my Wifi antenna coax up to the frig vent.
- TechWriterExplorerMe too. Keeps cable put & protects it from direct sunlight.
- MrWizardModeratoryes, i used strips to act like cable fasteners
5yrs still holding - Nor_WesterExplorerIf I recall correctly, mine was held down with white Dicor Self Leveling Lap Sealant.
Bill
38,778 PostsLatest Activity: Jun 10, 2026
