http://www.evanstempcon.com/service_parts.phpThe P/N may be the complete Evap assbly and NOT just the case. Use this link to see the Evans parts still available. Also, the plastic cover cracking is NORMAL on a evap cover over 5 years old. The plastic gets brittle and you have to take care to minimize further cracking when removing. Also, Monaco products from your years, the Dash speedo cluster bezel and dash ac control. Removing THAT, I always advise customers that the mount screws thru the bezel, odds are the area around the holes have spider cracks and the bezel will probably crack and you can see the spider cracks before it is removed. I have them sign a waiver that states if the bezel cracks further we are not responsible. Doug
PS, what is TAG????
