Executive45
Dec 21, 2015Explorer III
The high end coaches to which you refer incorporate those side rails into the front and rear caps. Trying to simply add the side rails would give the front and rear of the coach a strange appearance and would not allow the side rails to have sufficient support front and rear to support the added weight and stress placed on it from the awning(s). Then again, you could replace both the front and rear caps while adding the rails but the expense may be cost prohibitive. I do like the way the coaches look as the A/C units and upper exterior vents are hidden giving the coach a smoother look.....Dennis
38,763 PostsLatest Activity: Dec 05, 2025
