For those interested, here's what I did:
1. Removed the outer cover on the roof.
2. Removed the inner cover...plastic with screen. Many screws!
3. Made fan holder from aluminum stock from Home Depot.
4. Mounted four 120mm/130cfm muffin fans inside frame.
5. Inserted fan holder in flue opening.
6. Secured fan holder to side of flue opening.
7. Ran wires down alongside the fridge. (zip tied to solar wiring)
8. Tapped into the 12V supply on the fridge board.
9. Reinstalled the inner and outer covers.
Note: Replaced all OEM screws with Stainless Steel screws. Use suitable sealant when installing covers.
Addl notes: This was a temp "fix" as I didn't like removing the outside cover and bungee cording an A/C fan on the outside. Fans that PULL the air up over the coils are more efficient than fans that PUSH the air up and over them. Think whole house fans...that said, here's some changes I'm making over the holiday weekend...
Adding a snap switch on the upper part of the cooling unit to control the fans. (Snap switch provided by one of our members here on RV.Net :))
Removing the 12V supply from the circuit board of the fridge. The fans go OFF when the fridge is opened.:??, so I'm going to give them a dedicated 12V supply
I built the fan housing to exact flue opening sizing. This allowed me to squeeze it into the opening and simply screw it into the sides of the flue area. However, this also allows the fans to resonate inside the coach. Not much, just a low hum, but I'm anal about these things. I cut four legs that I will attach to the fan holder to lower it just below the flue opening. I should get the same air flow but without the noise.
If all goes according to plan, I'll take some pictures as I go so I can post them.....Dennis
