96Bounder30E wrote:
To get the rotor and hub assembly off the axle you need a socket that looks like this........but, first you need to remove the axle.......
Here is a video to give you the basic idea........
http://vimeo.com/66467738
Thanks! I actually just found this info. and the procedure for removing the rotor. Now, about the bearings in there, should I repack that all with grease? If so, what type? Thanks for the help.
Oh, and I asked the guys at Napa if I needed any special tools, because I recall thinking these duallys needed one, and they said no. So much for that. Hope I can get that spindle socket tomorrow.
