Ok, so a bit of advice still needed....
I've got the old bolt out and have a new metal brake line with a bending tool. I've got a grease gun, new tube of grease and a bearing grease tool to attach to the gun. I also have new seals ($30 each). My question is regarding the seals. The guy at Napa thought I was dumb for getting new ones and said just don't take the rear bearing out and you won't have to replace the seals, but I figure why not for $30 more make sure it's all done right.
Question is, the book shows a special tool for putting the seal back in... can I get away without using this tool? Is there another way to put the seal in without messing it up?
Thanks for all the help/suggestions everyone.
