Gator48's avatar
Gator48
Fan Controller
On our 2006 Itasca Horizon w/Cummins 400 We had some temp issues out west in June. Warning temps when climbing and I had to downshift to cool things off. Got home cleaned the RAD and all looks good. Issue now is the cooling fan runs all the time on high speed....IF the AC is on. If the AC is off it runs low speed. Doing some research it seems the fan should be off until the engine reaches operating temp. Then low until nearing high temps. Is this correct?
  • hostage wrote:
    Gator48 wrote:
    Thanks all,
    That's pretty much what I was thinking. Low fan all the time except for high temps OR AC on.
    I was reading on another forum a post from an owner who said "Freightliner said cold engine fan off to normal temp then low to high" mine has never done that.
    Guess I am ok....On to Texas later this month.
    AC on or off matters not fan runs on low till air and water temps get to max then fans come on to high
    Well,I can guarantee you this is not the correct analysis. Ask me how I know.
  • Gator48 wrote:
    Thanks all,
  • Thanks all,
  • hostage wrote:
    imgoin4it wrote:
    Not sure but I think the fan runs all the time when the acnd is on. Pretty sure mine does. In fact the engine runs a little cooler when the acnd is on,
    R U talking side cooling or rear cooling here?? My 425 ISL side cooling fan works strictly by engine coolant temperature
    makes no difference whether AC is on or off
    X2 in my 350 ISC.
  • Time for a fan clutch I believe. The fail-safe mode is 100% engagement.
    Sounds like your controller is working as it should. The fan does run at low speed all the time and as the temp rises to the danger zone, the fan will speed up. The fan does run faster when the air conditioning is on. Mine runs at a higher speed even when the vent mode is selected.
  • Not sure but I think the fan runs all the time when the acnd is on. Pretty sure mine does. In fact the engine runs a little cooler when the acnd is on,
