Vogelsang214's avatar
Vogelsang214
Fiberglass roof replacement
Hello everyone,
New member with major questions. Just bought our 1st Class A. Learned alot ot lessons already....so entire roof will need replaced in and out due to water damage, been pricing it out and will accomplish this on our own. I've watched many many videos and see that most fiberglass roofs go around the roof radius, ours does not. has separate radius cap. any helpful info would be great. anyone else have this also?
  • Finding more when you get home is not uncommon, probably more like the norm. The smell is a combination of dry rot and mold. No quick remedies except maybe a dehumidifier would help; I mean a machine, not the Dry's the air stuff. Keep it covered to stop any more damage. You could also put a hepa filter in it to catch mold spores.
  • If it were me, with a bad filon roof, I would peel off all that I could and replace all of the luan plywood that has rotted. Then I would contact one of the guys that sprays bedliner on trucks and have them coat the entire roof with a white permanent solution. Then you can reinstall your AC unit and roof vents.
    The spraying takes a few hours and the next day it is cured and ready to go.
  • Curious, HOW LONG and HOW MUCH money do you think it will be to get the RV ready? This is NOT like rebuilding a house. Doug
