rgatijnet1 wrote:
First I would get your coach weighed to see if you have a weight placement problem. Then I would replace the spring if it is shot. Last I would consider installing air bags to correct the problem.
Most shops don't like to work on motor homes because they take up space and usually cannot fit on to their lifts. Just go to a medium truck shop and see if they will take care of your springs.
I have four corner air bags but it was not to correct a lean but they allow me to air them up from the driver's seat to allow me to drive in high wind situations in the Great Plains without being blown about.
Thanks. It's not a weight distribution problem. Completely unloaded, the spring had a slight negative arc. The closest truck shop around me that has agreed to look at it is about 2 hours away.
