thefuzz4's avatar
thefuzz4
First Trip Issue and Questions
So we had our first trip with our new 96 Coachmen Leprechaun. The trip was an overall success despite the major mechanical problem that we had.
We're pulling with our camper, our car hauler with all of our ATVs on it and I knew going into the Colorado mountains that once we started to hit the hills, it would be slow travels going up, especially up and over Berthoud pass. So we got to our camp site for the weekend (which we did this from Jun2-5) which was way later than we anticipated due to leaving the house so late, once we got there I smelled what I thought was brakes but upon inspection all the brakes were fine, what wasn't? The tranny was pouring all of her blood out onto the ground. Thank goodness we had other people coming up on Friday and we were able to have them bring us some more ATF along with a bottle of Lucas Tranny additive (per camping world's service department recommendation) After adding the ATF and additive into the tranny we were able to move the camper around the site a little bit and ran it through its gears. We managed to get it back home on Sunday and took it into the shop on Monday. Well finally after a complete tranny rebuild she's back home and on the side of the house in her resting place. We have another trip planned to go back to the same area in a few weeks so I'm looking forward to putting that new tranny through its paces.
During the rebuild we had them put in the double billet torque converter which was on the higher end of the price range but we decided the extra 400 was worth it over a stock converter. The mech's told us that the converter is what failed and there is no telling how it happens it sometimes just does, and of course we have no way of knowing what the previous owners did to the tranny either.
So here is our question: does anyone have any idea what size the fuel tank is in this thing? They seller told me it was a 32gal but when I finally filled it up for our trip, she was at 1/2 tank (according to the guage) and took 31gal so either its got a 60gal tank or the guage/sending unit is bad. Thank you all for your help with this and can't wait to get back on the road.
    1. I had the converter go out on a 97 with the V10. I asked to see the part when they pulled it out.
    The malfunctioning part in the converter is PLASTIC! I was so ticked off that a manufacturing company would use plastic. :(
    Do you have the Ford Chassis? When overheated pulling a steep grade if the trans oil overheats there is an overflow and the trans fluid is designed to pour out. Doesn't necessarily mean the trans is lunched. Had this happen to me put oil back in and never traveled out west again. Tranny was just fine.
    2. Regarding the brake smell. I HOPE your mechanic also checked the emergency brake. On these the emergency brake is built in and stops the draft shaft not like the old days where the EB grabbed a wheel. It also holds "a 1/3 of your trans oil".
    If the emergency brake assembly starts leaking you can lunch the trans. Which came first? And did you mechanic thoroughly check your emergency brake assembly so it doesn't happen again?
    I had the torque converter go out first and only replaced the converter the trans was fine. Then the next year had to replace the Emergency Brake Assembly.
    3. HOW MUCH does your car hauler and all those ATV's weigh? IMHO JMHO I won't pull over 3,000 lbs. with a C. The V10 with the proper weight of a tow vehicle pulls steep grades with ease. If you are struggling and it's floating out your are way overweight for it.
