Anybody have experience flat towing a 2016 Chevy Equinox with a Ford Triton V10? Is this vehicle too heavy for a V10? Any problems such as the "death wobble" in later models? Thanks
You don't state which motorhome you have- generally the Equinox with a GVWR of under 5000 pounds should be no problem for a V10. Many newer class Cs, for example, with this engine can tow 7500 lbs. But you need to check your particular motorhome's towing capacity, hitch capacity and gross combined weight rating (GCWR) to know for sure.
