outofplace
Jan 06, 2017Explorer
I had to replace my power gear motor on my couch/Booth slide of my 05 Pace Arrow last spring easy job todo really. My motor broke some teeth on a gear so It would move a little at a time and make a bunch of noise when it got to the missing teeth. The motor will be in the middle with square tubes running from the motor to the gears that move the slide It will move fairly easy and once you r release the brake you can help push it in I did on mine, then set the brake to hold it there.
