Have 05 Fleetwood. Converter puts out 13.6 steady.Every 12volt light in the rig flickers when turned on. Anyone know what causes that? Just started about a week ago. Am on shore power. Thanks.
I had a problem in my 5th wheel a few years ago. Everything worked fine, but every so often the lights would sort of dim, then get bright. Turned out to be a bad converter/charger. The voltage at the converter/charger was, in fact putting out 13.6 volts. But, when the batteries "called" for charging, it would drop to 10.5 or so volts. I replaced the converter & everything worked as it was supposed to.
