Spizzer's avatar
Spizzer
Foam Mattress Question.....
All,
Coming home to Colorado we forgot to deflate our Sleep Number bed and blew out a mattress. Why they don't have a pressure relieve valve designed in it is beyond me....? This is our second one in just over a year in a brand new mattress. We were never really happy with it, so rather than putting more money into it, we are going to replace it.
From all the threads on the forum, it sounds like the foam mattresses are the way to go. Folks seem to be pretty happy with them. However, my question is: Are these mattresses too heavy and flimsy to move? My engine access for fuel filter changes is under the bed and with the air mattress I can just lift up the support and it stays there. With the foam I suspect I can't do that. Are they difficult to move off and around the RV for maintenance? How do you deal with this?
Thanks for any thoughts,
jeff
  • We have a foam mattress in our Journey. The lift supports hold will hold our bed up.
  • We replaced the sleep number bed with a conventional mattress (inner spring/foam top) and the gas struts on the lift worked fine. If yours is a similar set up you should be OK. The gas struts do come in different strengths and it's a pretty easy fix if yours doesn't have enough umph to lift it (I've had to replace a couple on outside basement doors).
    Doug
