MaverickBBD wrote:
Get in touch with this guy, http://www.daverootrvglassrepair.com/ Dave will talk you through the process
Thanks, I checked their Web site, looks pretty good, you get a kit for below 300$ and you can rebuild up to 5 windows. I only have two to do but I could keep the rest for more to come.
I checked with the guy that does house window and he says the little valve he install would be too big to put in between the glass. I also checked on the Web to drill tempered window, forget it, it will break. But drilling a hole in between a sliding window would be pretty easy and I think I will try it. If it does not fix it, I will go with the kit from daveroot.
