In all the post you read about fogging windows, its moisture getting trapped between the panes causing the problems, so how could we get rid of the trapped moisture.
Thinking, when you turn on the defrost heat to clear a fogged up windshield, maybe there could be some way we could have a constant flow of heated air blowing into these windows to clear the moisture out of them to solve the problem, but the etching over time what clouds up the panes & creating the safety hazard.
Has anyone done a temp test, to see how much difference the temp would be, between the double pane converted to a single pane window.
We lived for years with single pane windows in RVs, how much comfort would we be giving up going back to them.
Neil
