chilly123's avatar
chilly123
ford E450 windshield washer
I have a 2008 jayco 31ft on a Ford chassis
One day the windshield washer pump quit working. I have been unable to find a diagram showing fuse layout. Someone told me that the washer pump is controlled by a modual for the windshield wipers. Any words of wisdom?
  • My first thought was a relay or fuse, sadly this rig didn't come with the fuses or relays marked. Now after a two hour google search has led me nowhere.there is no power to the pump when the washer switch is pushed. I did try and jumper the pump with 12volts from the battery with disastrous results. So now i am back to square one
  • Hi,
    Are you getting 12 volt power to the motor? Check it with a volt meter or trouble light that will come on when it has 12 VDC.
    The engine should be on, and the wipers will run at the same time as the washer pump.
    A after market pump and reservoir are for cars that did not come with one, and only about $15 at a place like JcWhitney.com
    If you have no power to the pump, then start looking at the fuses, and relays.
    Good luck!
    Fred.
  • It could be a relay (not a fuse) that's causing your problem. Lookup (Google) your Ford truck and see what the wiring diagrams are. It's possible that it's a fuse, but a relay is more likely the culprit,
