zach477 wrote:
Do I need to do it now if the fluid still looks good?
I can handle an oil change on my own, but is the tranny fluid a similar DIY project?
If not, how much should it cost?
Thanks.
You have the Ford 5R110W transmission
Unless you have the ability to do a hot flush, you should hire this. Just replacing the fluid will
NOT result in a complete replacement of the fluid.
I have my local Ford dealer do this every 15000 miles, yes that is less then recommended, but I figure I work it extra hard. Cost is about $150
