zach477's avatar
zach477
Ford F53 transmission
My 2008 Fleetwood Fiesta has an 07 Ford Chassis. It currently has 34,000 miles. About 600 of those were put on by me, the rest by the previous owner. I just had the oil changed and they said everything looks good. When I check the transmission fluid it's nice and pink. I had assumed the previous owners had it done at 30k...
BUT, looking through theservice records left by the previous owners, I don't see that they had the transmission fluid changed at 30,000 miles as recommended. They did oil changes at all the correct intervals, but not for the tranny. At least that I can find record for. They kept everything very organized so if I can't find record of it, I think it's safe to say they didn't do it.
Do I need to do it now if the fluid still looks good?
I can handle an oil change on my own, but is the tranny fluid a similar DIY project?
If not, how much should it cost?
Thanks.
  • My PO said they did theirs too. I did it anyways. Empty the pan, refill, do it again next year. Don't forget external filter if you have one.
  • To clarify, the manual says that if it is a torqshift tranny to change at 30k, but for other automatic transmissions to just check it at 30. Not sure which transmission I have...any one know?
  • I would change the transmission fluid. Then you know it was done, and when.
