I've read all that before. It's legalize to try and avoid liability in case somebody gets gas in their eye, drips it on fresh asphalt, sets the coach on fire, etc. Before long they'll want you to disconnect the battery to check the oil. You're going to get more of a drip than a spray, when you unlock the fuel line retainers. It's only a liquid that had pressure on it when the pump shut off. I wrote
this thread about it. Notice the warnings in the first few posts. Such as being sure the new filter is the correct diameter and that its nipples are long enough to allow you to remove it with that 5/16" disconnect tool. That's NormK's warning and my pic showing the longer nipples on the small diameter filter. And Bryan's warning about filter size. Here's another thread by
BruceMc that takes you down the same path but with a few different wiggles and giggles.
I know you can't pull fuel through a Ford in-tank, high-pressure (as used with fuel injection) pump that isn't running. Still, I'd be careful to cap the line coming from the rear. Then it couldn't try to siphon the tank. I can't remember if anybody suggested loosening the gas cap so vapor pressure wouldn't be trying to push fuel to the filter area. This is an hour's instructions for a five-minute job.
