shawano
Dec 09, 2013Explorer
Ford V10 engine
Looking to purchase around a 36 ft class a motorhome to go full timing and wondering how the ford V10 is holding up. Will be towing a vehicle with it also. Please give good and bad points.
427435 wrote:C-Leigh Racing wrote:427435 wrote:C-Leigh Racing wrote:
So, after reading all these replys & owning a 99 F53 V10 myself & knowing what a good unit it is, I think if I was to design a chassis system for Ford, it would be the same chassis, 362HP V10 engine, 6 speed Allison auto, 22.5 buds & adjustable air ride instead of springs. Then require the coach MFGs to support their coach bodys with some sort of cushioning between the coach body frame work, instead of welding it direct to the chassis rails.
With all of that, what do you think the ride would be like.
Neil
How much more would you be willing to pay for those features???
With the market as it is right now, probably only difference would be the adding of air ride to the chassis.
The coach MFGs know, if they want to sell something, it better be to the buyers liking, unless the buyer just drowning in money & dont care.
Neil
I'll bet that the Allison cost to Ford would be several thousand $$$ higher than their own transmission; that an air bag suspension would add several more thousand $$$ (not counting engineering and tooling costs); and genuine aluminum Budds vs steel would be another thousand. And that is cost-----add mark-up and I could easily see $10,000 or more
Neil
Neil
Kiwi_too wrote:No big deal to us but for the used market guy, major deal, IMO.Pirate wrote:Kiwi_too wrote:2006 began the 362 3v engine.
Great engine. IIRC, pre '07 had 2 valve. Newer have 3 valve. Yep, some are noisier. check firewall, as some have gaps that let in hot/cold air, especially while driving. Also, hitch is 5k max tow.
Missed it by that much.
Neil
Neil
