swb7
Aug 27, 2013Explorer
Ford V10 gas mileage
This has probably been discussed before. Have a 2000 Minnie (24') & get 7.5MPG (Canadian gallons); is this normal. Have only had it a couple of months.
Thanks
Thanks
pnichols wrote:
The gas mileage "sweetspot" speed for V10 powered Class C motorhomes - if there is one - probably depends partially upon whether they're using an E350 chassis or an E450 chassis.
The two chassis have different rear differential gear ratios, with the E450 ratio being about 4.56:1, and the E350 being about 4.12:1.
gotsmart wrote:noe-place wrote:
With mine I have a 55 gallon tank. I keep it around 62 MPH or under and get around 7-9 or so.
X2 sounds about right. The best I've got was 9.1 mpg - includes pulling the toad.
Kit Carson wrote:My V 10 gets somewhere between 5 and 20, so I don't think about it, I just try to make more money and just keep driving down the road.rockhillmanor wrote:Is 55 the sweet spot for yours or all V-10's? I usually run no more than 60 and sometimes can squeeze out 8.2.
31 ft V-10
11 mpg....keeping it at the V-10 sweet spot of 55mph
Kit Carson wrote:rockhillmanor wrote:Is 55 the sweet spot for yours or all V-10's? I usually run no more than 60 and sometimes can squeeze out 8.2.
31 ft V-10
31 ft V-10
