Redram99's avatar
Redram99
Ford v10 loses power
Hi all!!
I have some power issues.
2010 e450 class c with the v10 and 90,000 Kms.
A couple of times in the past the engine has disliked aggressive acceleration and seems to kick into safe mode. This has happened when I am merging onto the highway and holding it wide open to get up to speed. It seems to drop from producing 300hp to about 200hp!! However, it’s only happened a couple times and if I pull over shut it off and restart it is all good again. This only happened 3-5 times over 3 years.
Recently, we did a 3000km trip around bc and on our way home, it started to act up but would not get better. We stopped for a little break, it was running like a champ and then hit the road and it “detuned” itself. Tried the shut off and restart and it would be good until I hit the first hill and as soon as I pull hard on it it detunes again.
As long as I can keep it in high gear it will pull hard. As soon as it downshifts and the revs pop up to 3500 it will pull hard for a couple seconds and then you can feel it drop power. And then will not smarten up for 10km or so.
It also wouldn’t provide any engine breaking coming down hill. The tranny would downshift but it would just go faster on hills that the engine would normally hold the desired speed.
Motor sounds great.
Not using oil.
Idles smooth and smooth at 4500 rpm.
Not overheating.
Tranny shifts good.
No codes
Any ideas?
I am going to do a air and fuel filter.
Thanks.
  • I had the same happen to mine. Changed the coil packs and plugs, a was good after that. I had 178 km at that time, traded it shorty after that.
