Anyone use a programmer for their gas engine? Is it worth it? I want to see if I can fix the down shifting so bad on overpasses. Thinking a programmer might help?
There is another thing I have done when it shift,s down unexpectedly. Most of the times I am using the "tow-haul" gear and am on cruise. If I am pulling a long grade and it happens, I turn off the tow haul and the cruise and the tranny will drop out of that high RPM's. Don't know why it would do it on flat grades. Are you in cruise with tow haul on?
