Team_D's avatar
Team_D
Ford V10 starting and dyeing
Hi All,
I have a Winnebago Vista, 32K with the Ford Chassis, V10.
I'm supposed to head out of town next weekend after the motorhome has been sitting for a couple of months, so I thought I'd take it out for some exercise.
I went to start it and it struggled. Typically, I turn the key and let go. The starter continues to turn the engine over until it starts. This time, it only turned over while I was holding the key.
It took several tries to get it started and then it would only start for half a second and then immediately die. I then started it while giving it gas and holding the key over. That seemed to work. I figured problem was just that it sat too long and a little drive would remedy the issue.
Drove about 15 miles and it died at a traffic light. I tried for several minutes and it would not start. Finally after about 10 minutes, I was able to start it, again only by holding the key over and giving it gas. Just 5 miles from home, I was able to make it without further issues.
I'll take it to my mechanic as soon as he can squeeze me it, but in the meantime, any ideas on what it could be? Bad relay perhaps?
  • When our 2001 F53 had pretty much the same symptoms, the cause turned out to be a bad MAF (Mass Air Flow) sensor. It's a relatively easy DIY repair, but figuring it out takes more than the average DIY OBD2 scanner.
  • Does the Class A chassis have the same fuel tank and fuel pump as the Class C models?
    It sounds very much like what happened to us when the fuel pump went out on our E450.
  • 2010 and no check engine light. I do have a code reader, but with something like this come up if there is no check engine light?
  • What year chassis? Is your check engine light on? Check for fault codes. Fault code analysis is ALWAYS the best bet when beginning troubleshooting diagnostics. If you don't have a fault code reader, they are available (for very little money) on the internet or most popular auto parts stores (Autozone, O'Reilly's, NAPA, etc.) can do it for you for free. Search YouTube for more specifics. The diagnostic port is inside near the top of the steering column to the right, . . . . usually. It usually has a black plastic cover over the port.
    Chum lee
  • Fuel filter
    fuel pump relay. not sure on Fords, GM fuel pump is run through oil pressure gauge.
