haste_makerExplorer IINov 23, 2022Ford V10Has anyone had to replace the throttle body on a V10? And if so what year was your unit & the amount of miles..
14 RepliesReplies sorted by NewestShow Morehaste_makerExplorer IINov 26, 2022Gjac wrote:What makes you believe it needs to be replaced?It will only idle & the code reads throttle body stuck.GjacExplorer IIINov 26, 2022What makes you believe it needs to be replaced?MountainAir05Explorer IINov 25, 20221999 and the only issue was Coil on plugs and a mouse family.pianotunaNomad IIINov 23, 2022130 thousand miles--no problems with throttle body. One mass flow air sensor. Unit is a 2004.
Related ContentFord V10Ford f150 PayloadFord V10 Triton2005 E450 Ford V10 intermittent misfiresFord V10 starting and dyeing
