OhhWell
Apr 21, 2014Explorer
Frame extension re-enforcement and tail sag
I have a '98 year bounder sitting on a '99 F53 Chassis. being that it's the '98 house, I have the Tag axle from that year even though it wasn't needed on the newer 20,500lbs chassis. The good is that I get an additional 1,000 lbs CCC and more stability on the road but the bad is that I have the weak frame extensions from the earlier chassis even though I have the GVWR to support larger rails.
I have begun to notice signs that I have the dreaded tail droop that affected the longer older Gas coaches. I had read somewhere on a post quite some time ago that someone had corrected that by jacking the rear up and re-enforcing the frame extensions. I'm wondering if anyone has fixed the sagging tail problem and if the fix was along those lines?
I know I would have to take it somewhere but was hoping to hear that it can be fixed and roughly what the cost might be.
Thanks!
Thanks!
