Thank you Mich
Very good information. I saved the Ford data in favorites for future reference. My problem is that my CRV weighs 3680 which is above the 3500 lbs. of most factory installed hitches. While I have no doubt that a 3500 lb. hitch will safely tow the CRV I really don’t like to be right at the upper limit. I’d rather have a bit of a cushion. My concern with the frame extension has been whether or not it is stout enough to install a heavier Class 3 hitch . With less than 3 ft. of extension I don’t believe there would be a problem. I would like to look at how the extension was constructed but I’m pretty sure Ford supplies the coach manufacture with specifications on how to do it and it would be more that strong enough to support a heavier hitch. One other thing that is not taken into consideration in regards to hitch rating is that towing a car places little to no tongue weight on the hitch unlike towing a trailer. The information I’ve been able to glean from the hitch manufactures refers only to towing trailers.
