jonlin wrote:
We are in NC and will be leaving for FL sometime around Christmas. Our forecast is for some mid 20 degree weather next week. If I run the furnace during these cold days will that eliminate my freeze concerns or should I winterize my rig for a couple weeks. I have a 38 foot Newmar Kountry Star. Thanks for your help.
John
RV anti-freeze (the pink stuff) is cheap and EZ to install. took me less than 30-min total to remove the inside water filters, drain the fresh and hot water tanks and pump the pink stuff thru the lines. used a couple of gallons ($5 total). if you have the equipment needed to blow out the lines that would be even easier. we still use the pink stuff as Winnebago told us blowing out the lines could damage our residential fridge.
