LaTriker's avatar
LaTriker
Fresh water drain
I own a 2019 Fleetwood Jamboree 30F. I cannot find the fresh water drain. Have called Fleetwood but they were no help. Can any Jamboree owners help?
  • LaTriker wrote:
    Found the valve. It was under the bed, under a panel that was attached to the floor with six screws. I don’t think they wanted me to find it.
    Good to know, thanks for coming back,was it near the water tank or somewhere in between?
  • Found the valve. It was under the bed, under a panel that was attached to the floor with six screws. I don’t think they wanted me to find it.
  • usually basic things like that are covered in the owners manual. In all the motor homes we have owned the fresh water drain valve is near the water pump, can you find the water pump?
  • I would give dealer a call - your rigs brand new and hopefully a salesman/tech will be available and give you answer.
    They would not help you?
    I'd be back on that phone until you were connected to a person that would.
    If all else fails I found going back to the dealership and talking to the service manager. They will tell you in a nano second where that drain is!
  • It is usually below or near the outside gravity fill port for the freshwater tank. Those fill ports are in close proximity to the holding tank which is also near the drain tube.
    Sometimes they put the valve inside an exterior compartment by accessing a small door or panel near the water pump. Locate your water pump and look for a valve.
    Sometimes the 2 low point drains also incorporate the freshwater drain, When you open the H/C low point drains, if the cold line seems like its taking a lot longer to drain, then you found it.
    Low point drains could be inside a removable panel under the fridge or under a cabinet. Some units have the low point drain exposed under the rv.
  • If you can get to your water tank check and see if it has a valve like this one at one end,just turn it and it empties the fresh water tank.
    That how my Fleetwood Tioga is.
