sparky3542 wrote:
I have a 2003 r-vision trail lite b+ and the fresh water level monitor stopped working. Suspect bad connection between the monitor and the sensors on the tank. I can see the tank by looking in the low point drain access but cant see any sensors. Does any one know where the sensors on the fresh water tank are located? I have switched wires on the monitor between switch positions to insure the monitor is working correctly. all indications is bad wire or connection between sensor and monitor
Does your floorplan for your model 285 look like this? -
Just looking, I would guess that your fresh tank is somewhere under the bed in back. It will be close to the water pump. Often times, lifting the mattress you will find you can remove the plywood cover(s) and see the tank.
Ours is similar to that. It is located under the dinette bench seat.
