bmwbob wrote:
Excellent!
Now, to save a bit of grinding on my old body from the coarse gravel in our campsite, can someone please tell me which side of the tank I should expect to find the sensors on?
The outside (curb, or passenger's side) will require me to remove the pegboard from that shallow bay (if that IS the fresh tank immediately behind it). Not a biggie, but as I said, being under the coach will be a bit uncomfortable, so I'd like to spend that time as efficiently as possible.
And here's another thought: won't I have to clean the surface of the foil and pads, then just glue the perimeter of the pads (backed up by duct tape) in order to maintain electrical continuity between the pads and the foil?
Bob
You have to remove the Pegboard on the pass side storage compartment. Once you remove the pegboard, you will see the foil and copper sensors on the tank. Doug
Also, NONE of that foil on the tank can touch any ground metal or frame. IF that foil touches any ground, the system malfunctions.
