sparky3542
Nov 11, 2015Explorer
fresh water sensors
I have a 2003 r-vision trail lite b+ and the fresh water level monitor stopped working. Suspect bad connection between the monitor and the sensors on the tank. I can see the tank by looking in the low point drain access but cant see any sensors. Does any one know where the sensors on the fresh water tank are located? I have switched wires on the monitor between switch positions to insure the monitor is working correctly. all indications is bad wire or connection between sensor and monitor
