JOERVDREAM's avatar
JOERVDREAM
Fried battery
I started to smell this rotten egg smell and after a lot of crawling around I traced it to the chassis battery. It was really hot and giving off that terrible smell. I disconnected it and took it out side and it took about 3 hours to cool off. I put a new one in the next day. I talked to someone later that told me to keep the aux battery switch off while Im connected to shore power because it over charged the battery? Or was there some other reason this happened and why only the chassis battery? The book says always keep the switch on unless your going to be hooked up to shore power for a long time while in storage. I have had the switch off since I put the new battery in for about a week now. Any ideas?
  • Normally, as your battery charges, it develops resistance to charging and the charging current drops to zero.
    When you have a battery that has a cell that has collapsed inside, the current in that cell merrily runs along, but it sees the battery as not charged, so it throws the maximum charging current through the battery trying to charge it.
    The result of this current flow is an off gassing, and cooking of the battery.
    What I did was I got a very cheap ($3.00) (Banggood) two decimal point voltage meter and put it across the battery terminals. Now, I just need to look at the meter to determine my battery voltage. I can monitor the amount of usage over time by checking the voltage. I can also monitor the drop in voltage when I hook up a big load like the furnace motor.
    Keeping an eye on your battery and understanding what is normal, and what is not becomes a habit, and after a while you just glance at the voltage and know everything is OK, or something is wrong.
  • Batteries fail. Generally 5 yrs is max but some 6VDC last longer. Anyway, my guess is your battery failed internally and cooked itself. Follow your manual's advice. Check your batteries monthly to ensure water levels are up. Also, if you have a battery bank, one weak battery will drag the others with it....Dennis
