- Big_RedneckExplorerI got one somewhere now to find it. Thanks
- littlemoExplorerHad this problem and my converter was bad.
- Big_RedneckExplorerDometic Model RM2611 I have it turn off now.
- DaHoseExplorerWhat model fridge?
- Old-BiscuitExplorer IIISo other than swapping to electric from propane have you checked any of the suggestions for WHY electric doesn't work?
- Big_RedneckExplorerThe frig works very well on gas. Last night I switch over to electric and this morning the ice trays were melted and not cold.
- wbwoodExplorerHow long did you wait for it to cool on electric? An hour or two is not long enough. You will more than likely need to wait pretty close to 12-24 hours. Propane will cool it faster.
- Old-BiscuitExplorer IIICools on propane but doesn't on electric....
Check for 120V AC at outlet fridge plugs into
Check 5A fuse on lower control module......it is for electric heater
Unplug electric heat element.......check resistance approx. 44 ohms
1994 vintage...probably needs new element (and fuse) - ScottGNomadMake sure the outlet at the back has 120V coming out of it.
38,760 PostsLatest Activity: Nov 14, 2025
